작성자 사진JONATHAN C&T
1080P USB Camera module
Unit (mm)
Connect 4P USB Line 1 DC5V IN
4P 2.0 Plug 2 DM
DC 5V Input
Video output1
2 DM
3 DP
4 GND
DC 5V output
2P 2.0 Plug
5 GND
6 DC5V OUT
1. Main Specifications
Model 1080P USB Camera module
Sensor OV2710
Sensor Size 1/2.7 inch
Pixel Size 3μm x 3μm
image area 5856 μm x 3276 μm
Max. Resolution FULL HD 1920(H)X1080(V)
Compression format MJPEG / YUV2(YUYV)
Resolution & frame 320X240 QVGA MJPEG @120fps/ 352X288 CIF MJPEG @120fps
640X480 VGA MJPEG@120fps/ 800X600 SVGA MJPEG@60fps
1024X768 XGA MJPEG@30fps/ 1280X720 HD MJPEG@60fps
1280X1024 SXGA MJPEG@30fps/ 1920X1080 FHD MJPEG@30fps
Special function Lens correction/ Defective pixel correction/ Black sun cancellation
Mini illumination 0. 05lux
Shutter Type Electronic rolling shutter / Frame exposure
USB protocol USB2.0 HS/FS
Connecting Port type USB2.0 High Speed
OTG protocol USB2.0 OTG
Free Drive Protocol USB Video Class(UVC)
AEC Support
AEB Support
AGC Support
Adjustable parameters Brightness, Contrast, Saturation, Hue, Sharpness, Gamma,
White balance, Backlight Contrast, Exposure
Lens Parameter Standard 3.6 mm, optional/2.5/2.8/3.6/6mm/FOV(D)187 Degree/170 Degree
Night vision Support, need to equipped IR sensor 850nm or 940nm lens and IR LED Board
LED board power connector Support 2P-2.0mm socket
Power supply USB BUS POWER 4P-2.0mm socket
Power supply DC5V
Operating Voltage 120mA~220mA
Working current 0~60℃
Working temperature -20~75℃
Board size /Weight 38X38mm(Compatible 32X32mm)/ about 30g
Cable Standard 1M / optional 2M,3M,5M
Operating system request WinXP/Vista/Win7/Win8
Linux with UVC(above linux-2.6.26)
MAC-OS X 10.4.8 or later
Wince with UVC
Android 4.0 or above with UVC
조회수 28회댓글 0개
Comments
